Old 10th November 2010, 04:27 PM
squbti's Avatar
squbti squbti is offline
Default wishbones steel thikness
hi all , just wanted to know what thikness are the tubes for the wishbones? mine are 2mm & it seems after my first test i might have to change them for 3mm .what did everyone use?
thanks/samy
Old 10th November 2010, 05:14 PM
3GE Components's Avatar
Hi Samy,
We' ve supplied a number of builders in Sweden with wishbone kits, ours use 2mm for the lower arms, we also supplied a certificate of conformity listing the material used, standard it conforms to, production batch etc etc, one customer did the calculations and the parts we supplied were satisfactory for the application.
Hope this helps
Kind regards
John
Old 10th November 2010, 05:39 PM
squbti's Avatar
thanks john, i know that the 2mm wishbones are what alot if not most builders in the uk & in sweden have been useing but what can one do when the tester says he´s not sure its ok thats why i´d like to know what anyone else has used & if anyone knows what the roadsters disign was based on , was it disigned fro 2 or 3mm for the wishbones?
thanks /samy
Old 10th November 2010, 05:45 PM
I know the lower wishbone material myself and Gus used was 25.4 x 3.25 Seamless tube, which I think was what the book said to use.
Old 10th November 2010, 06:55 PM
squbti's Avatar
i couldnt find anything in the book about the thickness, does it say it anywhere?
samy
Old 10th November 2010, 07:18 PM
Just for confimation from the man himself
http://www.haynes.co.uk/forums/showt...tube+thickness
Kind regards
John
Old 10th November 2010, 08:13 PM
rally205 rally205 is offline
But the book shows the 25mm tube as being 3mm wall thickness in fig. 5.5 on page 58
Old 10th November 2010, 08:20 PM
squbti's Avatar
thank you john that was just what i needed & it couldnt be better than to hear it the man himself .
samy
Old 11th November 2010, 06:59 PM
chrisunwin chrisunwin is offline
Hi
Whilst on the subject of wishbones. Is there any reason that I cant make them from square tube? Reasoning that it is much easier to cut all the angles on square tube rather than all that messing about with round miters which are a real pain.
Regards
Chris
Old 12th November 2010, 05:33 PM
Wynand's Avatar
Wynand Wynand is offline
mine were made from 2mm wall thickness tube 25mm OD.
Wynand
http://5psi.net
