Old 7th April 2011, 06:51 AM
Wgroove Wgroove is offline
Default Zetec Engine
Hi Guy's,
I'm planning to buy a ford zetec 2.0 engine from Kitspares.
Am i correct that after this i only need to buy an ECU to get it started ?
This is their description:
FORD 2.0 LITRE ZETEC ENGINE 136 bhp
The engine comes with the following ancilliares;
Fly Wheel and Clutch
Coil Pack and Leads
Exhaust manifold,Inlet manifold and Throttle Body
Injectors and Fuel Rail with regulator
Engine Wiring,Idle Control Valve
Water Pump
Thanks,
Wim
Old 7th April 2011, 08:48 AM
snapper snapper is offline
Check it comes with crank position sensor, water temp and oil presure.
May require air temp and/or TPS.
Old 7th April 2011, 12:48 PM
Personally i would give them a call or email and ask the question if everything is included to run the engine.
