Old 16th April 2011, 09:49 PM
Ashtonr Ashtonr is offline
Default Radiator Dimentions
Just fitted my nose cone and now I have found out the Nissan micra Radiator I've bought is too high by approx 30mm. Does anyone know the measurements of the others which are recommended i.e Polo etc ? I've had a measure up and it appears the maximum height I have availalbe is 500mm. Dont want to but two the wrong size !!
Regards
Rob
Old 16th April 2011, 10:45 PM
The polo rad is 340mm high by 500mm wide
Old 17th April 2011, 04:34 AM
Originally Posted by Ashtonr View Post
Does anyone know the measurements of the others which are recommended i.e Polo etc ? I've had a measure up and it appears the maximum height I have available is 500mm. Don't want to buy two the wrong size !!
Regards
Rob
1992 to 2000 Honda Civic radiators are 18" (457mm) Height, 15" (381mm) Width (these are measurements off my actual radiator. Bottom of tank to top of rad cap)
One of the nice things about them is that performance upgrade rads for this model are cheap and plentiful. Like this one
http://cgi.ebay.co.uk/HONDA-CIVIC-19...item35b14f047e
Some even come with the fan assembly. I bought a really cheap standard radiator to start with, if I want a fancy one later it will bolt right in.
Old 17th April 2011, 07:29 AM
Eternal Eternal is offline
Nice find! after a bit of searching this one looks the bomb.
http://www.mishimoto.com/honda-civic...00-triple.html
"Overall Size: 18.5" x 14.6" x 2.50"
Core Size: 13.78" x 14.09"
Rows: 3
Inlet: 1.26"
Outlet: 1.26"
Core Thickness: 2"
Tank Wall Thickness: .08"
Fill Neck Inner Diameter : 1.22"
Fill Neck Thickness: .12"
Drain Plug Thread Size: (M16) .06"
Drain Plug Thread Length: .047""
That one should handle my engine with any luck lol.
Skyline Roadster
Old 17th April 2011, 08:31 AM
Regards
Rob
Aww bu99er - I've got a micra radiator too
I thought it looked a bit on the tall side when it arrived, but hoped it might just fit.
What's the height of yours? (on the off chance I've got a different year...)
Old 17th April 2011, 11:41 AM
My Micra rad approx 540mm tall, I have tried tilting it back but the main problem is at the bottom od the nose cone there is only roughly 90mm where you have the full height the cone then tapers in so its not possible to tilt much the filler cap is always to close to the cone. The other options look ok though especially those civic ones
Old 10th May 2011, 09:32 PM
vtecmike vtecmike is offline
hey, i bought a civic rad to fit my roadster , but i found the outlets hit the chassis!
has anyone got a picture of they re rad fitted so i can place mine?
thanks mike
Old 11th May 2011, 09:27 AM
jamesbissland jamesbissland is offline
I have this web page from a place here in NZ that I saved in my book marks from my last project
http://www.a1radiators.net.nz/index....index_new.html
It has heaps of dimensions from factory radiators and what make and models they can be found in - also the inlet/outlet configuration
Hope this can be of help for someone
James
