Old 11th July 2011, 02:01 PM
Tim Taylor Tim Taylor is offline
Default Clear Flyscreen
I am looking for a clear Flyscreen similar to this:
Thanks to Dunk3 for the pic
Old 11th July 2011, 04:04 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
If I remember from my school days you can manipulate perspex just with a little heat from a heat gun so you could make one quite easy
Old 11th July 2011, 05:51 PM
a halogen heater on its back will be good to bend acrylic, i remember too using a line bender to do that job! but there well in excess of a 100 spondoolies!!
just be carefull!
Old 11th July 2011, 05:59 PM
vmax1974's Avatar
Then file and polish the edges and your done ...... Oh no just realised I did learn something at school lol
Old 11th July 2011, 09:25 PM
you can also finish the edges with a blow torch if your quick the trick is go fast enough not to warp but slow enough to melt and soften the edges
like doing a creme brulee best to practice tho !
you can improvise to make a line bender bit of copper pipe and a blow torch ?
Old 11th July 2011, 09:49 PM
I can say that a torch was a bit too much. There were bubbles at the bend. no amount of sanding or polishing would get rid of them (That was a waste of an hour or two).
This is Lexan so it would bend with a brake if I had one. I might give it another try.
Old 12th July 2011, 10:03 PM
i hope you used a test piece ? not a waste of time experimentation is never wasted time. you now know how not to, but has it shed any light on possibly how might to ?
Old 12th July 2011, 10:12 PM
The screen looks very similar to ones produced by MAC#1 sportscars
Old 14th July 2011, 02:25 AM
That is a Mac Flyscreen but they don't make them for the Haynes.
Unfortunately the piece I used was supposed to be the final piece. At least I have a template fpor the next one.
Old 15th July 2011, 12:24 AM
I watched a guy heat forming some lexan screens and he pre heated the plastic in an oven then layed it on a shaped wooden plug. The stuff sort of glooped into shape and was allowed to cool. Then trimmed and polished it, these were only small so i dont know how you would get enough heat into a piece that big without a huge oven. Dont think you would get away with a heatgun.
bob
