Old 6th June 2011, 02:16 PM
MikeB MikeB is offline
Default Brake pipe p clips and connectors
I need to order the bits and peices for the rigid brake lines for rear drums.
All I need at the minute is the bits to run the rear brake lines. So any help gratefully recieved.
What P clips are people using, size and spacing and where from?
Has anyone drawn up a list of all the connectors and parts?
I sketched up this diagram but wanted to add a parts list so if anyone has the sizes of the connectors and t pieces please let me know, If its useful I'll draw it up a bit better with a parts list.
1. FR master cylinder connector - size - part number - supplier/price
2. FL master cyclinder connector
3. Rear master cyclinder connector
4/5 Brake Pressure Switch and T Piece and connectors
6.
Old 6th June 2011, 06:58 PM
SeriesLandy's Avatar
1x 25ft reel 3/16 copper brake pipe
1 x Tee Piece (3 way union)
4x 10mm x 1mm female union
6x 10mm x 1mm (25mm long) male union
Brake pipe flaring tool
P clips, 5mm (think it was 4.8) from Maplin
4 x flexi hoses
Old 6th June 2011, 07:44 PM
put the pressure sensor in the rear line. i had mine in one of the fronts and it created a pressure imbalance between the two front sides
My Pictures
Old 7th June 2011, 09:42 AM
thats an odd one all the rules say all hyd pressure is equal in the same circuit
Old 7th June 2011, 02:55 PM
are the male unions longer than the standards ones on ebay?
e.g
these
http://cgi.ebay.co.uk/Male-brake-fit...item4aa96b1dbc
or these
http://cgi.ebay.co.uk/Male-brake-fit...item4aa96d715a
the short ones seem to be standard
Old 7th June 2011, 03:32 PM
I used the one from the lower link, I have an assortment of sizes so picked the ones I felt were the correct length.
