Old 21st July 2011, 08:32 PM
SeriesLandy's Avatar
Default Vin Plate for IVA
This evening I made my VIN plate after recieving my number from the DVLA.
I intend to weld this to the chassis.
Section 18 Statutory Plates:
12.The characters used for the VIN stamped into the chassis, frame or other similar structure must be at least 7mm high. This does not apply in the case of a "Visible VIN" provided on a Mass Produced vehicle
I used a centre punch to etch the characters, is this ok?
5.The Stamped in VIN must be marked on the chassis, frame or other similar structure on the right hand side of the vehicle. (see note 5 & 6)
I'm assuming this is the off side?
6.The Stamped in VIN must be placed in a clearly visible and accessible position by a method such as hammering or stamping so that it can not be obliterated or deteriorate.
I was going to weld my plate onto the top of the diagonal rail in the chassis bay, is this acceptable or not? Pretty much anywhere it is put it can be tampered with a hammer.
Old 21st July 2011, 09:27 PM
Yeah that was on LB last week (maybe one before)
I don't really see the difference between a bit of 3mm plate welded to the chassis or actually stamping the chassis (apart from covering up an existing vin)
Both can be damaged with an angle grinder.
Old 22nd July 2011, 05:28 PM
Talking stamp
Steve i think you would struggle to stamp direct onto the box section as it would just dent. At least with a 3mm plate you can support it with a lump of thick metal and give it a good thump, i doubt if stamping direct onto the box section would come out legible.
just my 2pc
Old 22nd July 2011, 08:25 PM
Heres one I made eariler (well last night).
I used the back of my vice as its solid and a sharp centre punch. Hope its ok.
The letters are 10mm high as it says larger than 7mm.
just my 2pc
Old 22nd July 2011, 09:00 PM
I could have a go an CNC engraving one, depends on how soon you want it?
Adrian
I'm not in a rush, keep on finding things that need remaking. It's annoying me a bit. Dropped the engine in today and the steering column hits the mounts. Need a solution for that now.
Old 24th July 2011, 01:29 PM
They look really good, cheers Adrian.
Old 24th July 2011, 01:58 PM
Deanno's Avatar
Deanno Deanno is offline
how early can you apply for the VIN number and is this the bit that cost's?
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 24th July 2011, 04:25 PM
No it's free, don't know how early you can apply but I don't think there is a time limit on the number.
Just use ash's letter in the amendments thread and change it to suit yourself and your local dvla office.
Old 24th July 2011, 04:50 PM
Deanno's Avatar
Thank you for that
Old 24th July 2011, 05:23 PM
eSteve's Avatar
eSteve eSteve is offline
Default VIN number's free, just ask...
Deanno,
I got one quite un-expectedly one-day, see story here:
http://www.haynes.co.uk/forums/showthread.php?t=5188
Although it possibly depends on the DLVA office and staff, so YMMV.
Regards,
eSteve
