Old 2nd October 2011, 05:52 PM
Default my fowaki injection/inlet system
fired up the tig today nd cut some alloy tubes to make my ford sandwich plate fit my zxr636 38mm throttle bodies.
i have removed the ecu controlled butterflies and im not sure witch set of injector im going to use yet ford or kwack? im thinkin ford as there right at the port and i dont want drop out probs at idle hope 195cc/min will be enough?
just thort you all would like to see what i done today
[IMG]
[/IMG]
