Hi Guy's
Have just started fitting my wiring. But i have a few problems. One of my problem is. My sierra donor was originally fitted with 1.8 cvh, at some point it had a 2l pinto fitted. The cvh engine loom was hacked about to fit the pinto, i was wondering if anyone had a proper pinto engine loom they didn't need in exchange for beer tokens. The next problem is i've lost all my pictures i took while disconnecting the electric from my donor , so remembering what went where is going to be a bit tricky .So i will be posting up some pictures and asking what is meant to be attached to this and that. A big thanks in advance for any help that i my get. Terry
If you need a friend, call me, if u need company call me, if you need help call me, if u need money this number is no longer available. |
Most pintos where wired up quiet basic so should not be to hard to get it all sorted
Did you not go for a new loom come the end? |
Hi Baz,
no didn't get one, but the way things are looking i my have to go that way. the loom i've got, was from injection engine and it was hacked about quite badly. Terry
What have you actualy got?
A sierra 2.0 Pinot (carb) model should be runnign an ESC-2 spark control, the 1.8 CVH will have had a ESC-Hybrid. Or is this a PRE-Sierra 2.0 running Points? TT
I'm running a, 2L Pinto with weber twin 40's with a electronic dizzy.
Terry
If you need a friend, call me, if u need company call me, if you need help call me, if u need money this number is no longer available. Last edited by tkpm : 18th June 2012 at 05:05 PM. |
Who's dizzy? The ford one or an aftermarket one?
It's the ford one, will post up some pic's later tt.
You will need the ESC-2 module to go with it then, as well as the loom.
sorry about the delay in pic's,
is this ESC-2 you was on about TT, P6200069.JPG carbs P6200072.JPG dizzy P6200077.JPG coil P6200078.JPG coil wires, does it matter which way round they go on the coil. P6200073.JPG
Ahh, my mistake it runs basic TFI not ESC ( my poor memory ).
But yes that module is your ignition amp. TT
