|  Front wings hi guys, When you mounted your front wings, did you have a measurement or point of reference to the rotation position on your front wings. How far they rotate back etc?? |
|   Hi if you look at the IVA regs, there are measurements to tell you how far the wings must cover the wheels back and front. Regards Mick. |
|   Hi, I have found that, was just interested if anyone had used a point, chassis side member etc as their reference. |
|   I haven't got that far myself, but would have assumed you'd do it off a vertical line through the centre of the hub? I.e. a spirit level or similar?
				__________________ http://meandthekitcar.wordpress.com/ |
|   Hi ya, yeah after I lined up and measured the angles etc, seems a good position is to have the rear edge sitting on the center line of the hub. |
|   Quote:
 Given the IVA requirements you might not be able to rotate the front wings back far enough to solve this problem, but I think it's something worth thinking about.
