Old 8th July 2012, 09:57 PM
tkpm tkpm is offline
Default Mega Fuse
I was thinking of fitting a Mega fuse in to my ignition feed as there doesn't seem to be one.
What size fuse would be best?
Terry
Old 8th July 2012, 10:41 PM
Depends what's hanging off it... 3A to 100A... The size depends on what your running.
Old 8th July 2012, 11:58 PM
only the starter and coil,
Old 9th July 2012, 07:44 AM
Starter as in Solenoid?
Old 9th July 2012, 10:42 AM
Yes TT starter solenoid
Old 9th July 2012, 12:38 PM
you won't need a mega fuse for that,
your only going to be lookign at 10amps maybee..
I will have a look at the ford diagram later & see what it has.
You could just try 5,10,15 and see which popps..
Old 9th July 2012, 09:49 PM
Sierra is unfussed appart from the Fusible link (try finding that)
