Old 20th November 2012, 09:23 PM
Cool A neat engine mount.
I found this on one of the rod forums. A neat and simple way of restraining an engine. Note the trickery on the steering.
http://i1288.photobucket.com/albums/...emounts004.jpg
Old 20th November 2012, 09:54 PM
PorkChop PorkChop is offline
Is that engine mount one piece or is it welded? It does look neat
Old 20th November 2012, 10:05 PM
Its hard to tell but it could be made from 25mm box without a problem. The only turned bit is the bush housing. That bush idea would also be a good way of anchoring the mx5 diff in place. it would beat the dubious engine rubber idea.
Old 20th November 2012, 10:16 PM
That has been milled out of one piece of steel you can see the end mill marks in the corners of the open section.
Old 20th November 2012, 10:25 PM
I'm not convinced, if you look carefully at all the corners/joints it bears the hallmarks of being hand finished.
Its also consistent with the chassis finish.
Just my opinions like
Old 21st November 2012, 06:50 PM
Dualist's Avatar
Dualist Dualist is offline
Flame cut profile.
Arrow points to a 'start' for the inner cut, must be 20/25mm plate.
Old 22nd November 2012, 06:56 PM
John.W John.W is offline
I saw these on German Bay for a zetec, don't know if the picture works?
Regards
John
www.rallyx.de
