Old 4th December 2008, 12:48 PM
gus's Avatar
gus gus is offline
Question Wiring Loom
Could anybody tell me what wiring looms they have been using.
I am looking at using the complete loom from the donor, and removing all the parts not needed.
I was wondering if I do this where is the best place to site the fuse box. If it is like the donor then it will be on top of the pedal box, or close to it.
Any advice appreciated
Old 4th December 2008, 03:40 PM
I used the wiring loom from the donor Sierra, sited the fuse box within the bulkhead / firewall. it'll then be hidden by the dashboard. Took all the unnecessary sections off, its just time consuming and fiddly but well worth it.
Old 4th December 2008, 04:31 PM
Jezzer99 Jezzer99 is offline
spud69 - like your exhaust - where did you get that from?
Cheers,
Jeff
Old 4th December 2008, 04:33 PM
gus's Avatar
gus gus is offline
Looking at your photos, the fuse box looks like it is set through the bulkhead. Are fuses accessable from with in the engine bay?
Did you retain the security module? If you did how did you get it to work without the central locking system? Have you got a hidden switch that only activates the immobiliser part of the system?
Thanks for reply
Old 4th December 2008, 06:48 PM
Exhaust - to keep costs cheap i re-used the existing 4 to 2 manifold from the sierra then turned the 2 into 1 so that it came out the side of the car instead of underneath. Then welded a 2" x 90 bend and some 2" steel pipe onto a 2" silencer off e-bay. Finished with a couple of coats of exhaust paint. Color scheme is orange and black so turned out pretty well all in for £40.
Fuse box - The lid to the fuse box is in the engine bay so is easily accessible. wrt to the security module as long as you remove the wiring loom with the central locking unlocked it will stay deactivated. I've then rivetted it to the bulkhead out the way.
Cheers...Andy
Old 5th December 2008, 08:03 AM
gus's Avatar
gus gus is offline
Did you then just cut off the central locking wires, leaving only the two wires for the coil feed connected to the security module? Do you still need to leave the live feed & the earth conneted to the security module?
Thanks
Gus
Old 5th December 2008, 11:04 AM
Andy - would be good to see a few more pics of your exhaust manfold arrangement if you can? What's the engine you're using? Is it a CVH?
