May be one for Twinturbo/Robin but does any body know if there is an air mass/flow sensor on the underside of an EFI 2.9 cologne air box? I've seen the twin meters side by side on the Sierra but my engine came from a 1994 Scorpio and I'm thinking the reason it does not idle properly is because the system is not complete?
The photo is of a later 2.9 Using MAP sensor and Lambda Control.
Early 2.9 Used 2 air flow meters TT
P.S...
Check the Lambda sensor and clean the idle speed control valve. TT
Ah thanks for that I was looking for a part that was never fitted in the first place. I've cleaned the idle valve so I'll pull the MAP and treat it to a pair of new lambda sensors.
What car is the engine in?
Mk5 transit 190 chassis cab with adaptor plate to fit transit MT75 gearbox custom fabricated 40mm 3-1 manifolds in to 63mm exhaust and LPG gas kit.
