Old 21st July 2013, 07:03 PM
jps jps is offline
Default Floor cutting - isn't alu supposed to be soft?!
Been trying to cut out the floor panel today. I'm going with what I could get for free - which is a 3mm thick sheet of alu - no idea what grade - but it is an old pub sign.
Anyway - i'm getting through jigsaw blades at a tedious rate. I am assuming this is because the alu is so soft it is clogging the blade. The cutting disc on the angle grinder was worse than useless - presumably for the same reason.
Am I right - and what can I do to cut the alu more easily / without the constant snapped blades!
Old 21st July 2013, 07:19 PM
davidimurray's Avatar
Get some proper 1mm thick stainless/ALU cutting discs.did all my sheet work with them and made the job a doddle.
Old 21st July 2013, 07:28 PM
Oscar Oscar is offline
You can get Ali specific blades for a jigsaw. They've got extra large teeth!
Might have a hard time on 3mm stuff regardless of blade though, you're best bet, as Davidimurray said, would be some proper discs for the grinder.
I've used them for a few pieces and they go through it like butter!
Photos of the project so far:
Old 22nd July 2013, 09:02 AM
Ali and angle grinder just five words for you WEAR A SODDING DUST MASK!
Old 22nd July 2013, 10:10 AM
I must whole heartedly agree with Phil on this one, as someone who has just recently left the aircraft industry you are enlightened to the effect that Chromates have on you by breathing them in and believe me when I say it aint good.
WEAR A MASK
Old 22nd July 2013, 12:40 PM
Add some WD40 to the cuttign surface.
