Hi all,
I'm after a very cheap set of 15/16in steel wheels with tyres so i can get my chassis on wheels if anyone has any? Preferably near surrey area so I can pick them up. Ben
Build photos: http://s1056.photobucket.com/albums/t362/benbrooks1/ |
What donor are you using? If its an mx5 I've got 4 space savers that I used you can have for free as long as you arrange a courier
sorry, should have said in my first post, i'm sierra based. thanks for the offer though
it's it possible to get steel wheels that big? I thought they were all 13s?...
14" are OK too, my build wheels were that size. Sierra did come with 13" and 14" wheels.
i tried 14s on the rear and the long bolt on the bottom of the upright scrapes against the rim, even though i cut a bit off
okay cheers guys, i will try again but might try Richard's idea if they still won't fit.
I had to cut my bolts to 233 mm. This way there is one turn of the thread above the nylon. This way the wheel fits, but the clearance is minimal
cheers for that alga, i've been being a bit more generous with the thread - leaving 3-4 full turns but suppose i could cut it down a bit more.
