Old 12th August 2013, 04:51 PM
Enoch Enoch is offline
Default Hit a Snag - Universal Joints
Hi folks, have been busy building and am now trying to join the steering column to the rack. It is giving me a massive headache, I just can't make it work and still give me the angle I need in the run to satisfy the IVA man and miss my exhaust downpipe. The donor car had a really weird double uj sort of device that attached to the rack, there was a uj right up near the column. It won't work on my car because the angle is too steep and it just locks up. What I was thinking was to put a standard uj on at the rack end and try that. What I don't know is where to get a UJ to fit. The shaft I need to attach it to is 5/8 inch / 16mm diameter. Anybody got any ideas? I thought about using a Sierra one but from memory the steering rack splined shaft was only 1/2 inch - can anyone confirm if that is the case?
Old 12th August 2013, 08:04 PM
Short Short is offline
whats your donor? and what rack are you using?
any photos?
Old 13th August 2013, 08:38 AM
Hi there, donor is Jag XJ12. Steering rack is the original PAS rack, the spline is 5/8 inch, the spline on the column is 9/16. I think I may have to cut the rod that comes down from the steering column and put a second uj in half way along. Unless anybody has any better ideas? Don't want to go to a Sierra or other rack as I am going to need the power steering.
Old 13th August 2013, 12:37 PM
jps jps is offline
aren't there some good electric power steering solutions available now? (corsa rings a bell for some reason?) Wonder if this is worth thinking about rather than keep the donor pas?
Old 13th August 2013, 03:13 PM
Silly suggestion,what about u/j from socket set ?
Old 13th August 2013, 04:39 PM
I have broken quite a few of those.
I think the MX5 UJs are is 16mm splined, the Escort IIRC are 15mm. Certainly when I offered the MX5 one up to the Escort rack it wouldnt pinch up enough to bite the splines properly. Problem is the MX5 spline may not match what you have?
Ill take a look tonight. I need to finish welding up my steering column anyway.
