Old 29th December 2013, 05:29 PM
james3004's Avatar
Default Zetec help
Been having problems with the ZVH, so I've decided to build a zetec for the car, first hurdle is where to the pipes on the picture go to?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 29th December 2013, 09:26 PM
2 to the fuel pressure regulator on my setup, the others probably brake servo and fuel vapour recirculation, you can plug them.
Old 29th December 2013, 10:55 PM
james3004's Avatar
Thanks alga, how have you set up the breather system?
--- James ---
Flickr Album
Old 30th December 2013, 10:52 PM
Yes. I have a small filter on the valve cover breather. The bottom part of the system is standard: a metal tube coming around the back of the engine connected to the PCV valve and the intake manifold with short pieces of rubber tubing.
The breather on the valve cover (air intake for the PCV system) leaks oil a bit, I suspect because of surges during cornering, so I plan on adding some catch can there.
Old 31st December 2013, 07:10 PM
Shorty Shorty is offline
1. Is brake servo, just needs blocked
3. Looks like the other end should push straight onto the fuel pressure regulator
I wasn't sure about 2. What is the fuel vapour recirc system actually for?
I'm also planning on using a zetec on standard inlet and look exactly the same. I'm guessing from a focus as I think the mondeo inlet is slightly different.
Old 31st December 2013, 07:33 PM
Recycle fuel vapor through carbon canister back to fuel system so that it is not lost to atmosphere.
