Help required please ! I have been trying to put my rear upper mx5 spec wishbones together, by using the saturn & gillham plans. Unfortunately, my plans seem to be missing a few dimensions like suspension bracket location & the distance from the bush tube side of the jig to different components on the wishbone. Has anybody got a more up to date build spec ? Or some measurements to help me out a little please ? The vague build spec can be quite frustrating at times. Any help is greatly appreciated !
Ah yes it can be a problem when people say 'it looks like that and it's about this long' for those that can't see my hands from where they are my fingers are 'that far apart'.
This may help a little, many thanks to forum member 'Stot' for drawing this one wednesday afternoon. ![]()
Unofficially rated No.1 supplier of fabricated Haynes Roadster parts by the workshop rat population. Direct email talonmotorfabrication@gmail.com |
Massive thanks Phil ! Happy new year mate.
I will agree with the thanks for this, just about to start making up my wishbones, I have my frame now in 3D and even have the steering wheel support, column and pedals SITTING in place, my frame is only tack welded together at the moment. The rear frame still needs to be made to so I can fit the MX5 diff. PLUS a Happy New Year to ALL. ![]() |
I am a little confuzed, I have compared stots plan of the rear upper wishbones to saturn sports cars, ( saturns plans were in complete), and they very significantly at the hub end. On the short arm side, stots plan says 56mm from the board at o/s edge & saturn says 51mm, & at the other end of the upright bracket, ssc have the finishing point 10mm wider at the o/s point. I have followed the vague ssc plans throughout, but the rear wishbone plan was incomplete hence asking for dimensions on line. Car body side of the wishbone & shock bracket positions are identical. So, some help is required once more sorry ! I am building these babies up today, and don't want to do it twice. I can't check against my mazda, because the car is being stripped a few miles away. Confuzed.com !
Hi Jason,
My plans are of the actual wishbone dimensions. The saturn drawings measurement here are of thier jig. ![]() The 51mm measurement is to the outside of the tab in their jig, which is 5mm steel, hence 56mm to the outside of the bracket on my drawing. Thats where your extra 10mm is coming from too, 2 x 5mm jig tabs. Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
