I have some really nice headlights from Staffordshire vehicle components.
I have fitted them finger tight and wired them in. My question is how do I tighten them? I cannot get a socket on due to the wire ans can't use a spanner as the nut is recessed.... Confused.com Thanks David
Box or Tube spanner, removing wires and socket after setting lights to where you want them.
Be Lucky, Mike.
As above or cut a slot with grinder out of socket and put the wires in the slot,or put wires through hole in socket and use molegrips or the like.
Johno and Tatey had a discussion about that, and there are some pictures of the "home made" socket:
http://www.haynes.co.uk/forums/showt...t=2736&page=24
I may be way of as i am no where near lights etc yet but my thoughts are to fit the bowls first then wire them in.
My build diary is at http://thailoz.wordpress.com/ |
My solution, as eluded to in that thread, is to drill a hole in the thread and exit the wires just below the top mount and into my mount tube. the thread then continues down and out of a lower plate at the base of the headlamp mount and that can easily have the nut done up with a spanner ( and the wires are fully hidden ) .
The big advantage is that the lights can be adjusted without disturbing the wiring ( IVA Bonus! ) if the mounting bolt also acts as the adjuster clamp like mine. TT
