Old 19th June 2014, 10:22 PM
rolsty rolsty is offline
Default Haynes mx5 donor stripping
Hi everybody
I have a mk2 mazda mx5 that I am stripping for my son and my Haynes roadster build.
I have a question about the parts I will need - as far as I know they are engine, gearbox,prop,diff,wiring loom,ignition switch and stalks , steering column,speedo,front and rear hubs and brakes, handbrake .
Is that all I will need ? Am I missing something ? I recall something about a charcoal canister on the fuel?
I need to get rid of the shell to the scrappy as the boss isn't appreciative of it on the drive !!
Thanks in advance
Old 19th June 2014, 10:54 PM
Originally Posted by rolsty View Post
Hi everybody
Thanks in advance
Hi,
I junked the charcoal canister so you don't need that. Don't forget the wheels!
Welcome to the forum
Old 20th June 2014, 02:41 AM
johnl63 johnl63 is offline
all the nuts and bolts you can find, the fuel lines and the clips that hold them in, the brake lines and the fitting off them, fuel pump from tank.
I just kept using bits from my MX5 till I could think of nothing else.
Haynes MX5 based New Zealand
Old 20th June 2014, 08:36 AM
Before the shell goes don't forget to cut the VIN plate out of the engine bay and take pictures of the factory production stickers inside the door jams.
Old 20th June 2014, 11:25 AM
thanks everybody- I most probably hadn't forgot the wheels
seems like I've got it all off then
I did phone dvla about scrapping the chassis and they said there was no reason to keep it and sorn it - just photocopy the log book and get the destruction certificate, I have photographed everything including my 10 year old son taking the engine out ( i'm not a slave driver !)
Old 20th June 2014, 05:03 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
slave driver lol
cut the plates out and sorn it so it wont come back and bite you later just my opinion
