Old 7th January 2015, 09:53 PM
onedayTM onedayTM is offline
Default Rivnuts?
This may sound daff! is it steel ones for steel and ali for ali?
Old 8th January 2015, 04:15 PM
Agreed. I've used ally ones and already I had 2-3 bolts stuck with the rivnut turning in its place.
Old 8th January 2015, 11:35 PM
ok cheers for that
Old 9th January 2015, 02:45 PM
MikeB MikeB is offline
There a compound you can put in to stop the reaction between metals, we use to use it putting steel helicoils in to ali tank hulls. Can't remember what its called though!
Old 9th January 2015, 03:15 PM
Squirt of WD40 into box section would not hurt either .
Old 9th January 2015, 09:17 PM
do people use ali because they are easier to form then?
tony
Old 14th January 2015, 12:23 AM
Ste W Ste W is offline
Mastinox it's called. We use it in work on Eurofighters
http://www.silmid.com/products/masti...-27-mil-p.aspx
