Old 27th January 2015, 01:32 PM
Default MX5 Engine Mount Hole Spacing?
Hello all,
Just wondered if anyone happened to know the distance between the three holes on the MX5 engine mounts? (for both sides, as I think they're slightly different).
Or had some lying around and could measure for me?
Thanks!
Old 27th January 2015, 01:48 PM
I have this if it helps. The slotted hole has the bolt to its inward side when fitted.
You can measure in Adobe Reader in theory. Edit -> Analasys -> Measuring tool.
I make it 45mm centre to centre vertical and 102mm centre to centre horizontal to the start of the slotted hole and 108mm to the centre of the end of the slotted hole.
Old 27th January 2015, 01:54 PM
Perfect! Cheers Stot
Old 27th January 2015, 10:43 PM
What you up to?
Old 27th January 2015, 10:50 PM
What you up to?
Nothing very exciting, just making some new engine months after one of my old ones failed:
http://www.haynes.co.uk/forums/showthread.php?t=13553
Old 27th January 2015, 11:04 PM
Ahh I see.
