Spending ages putting trim on stuff at the moment. I am a bit stuck with how to cover the locknut on the top drop link. Also do I need to cover the cast flats on the track rod ends? Tempted to just grind them off!
Thanks for any advice anyone! |
Ken, you can buy some large diameter heat shrink and cover them that way, or a lot of people on Locostbuilders use old bike inner tubes stretched over and cable tied on.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting
For the track rod ends and the steering rack extensions I used electrical glands but furore kit cars sell them cheaply. David
I used armoured gland boots to cover the rack extensions and top ball joint nut.
Mine came off the internet a lot cheaper than fueore. I googled something like replacement swa boots. They were also thicker and more rubbery than the screwfix ones. And much larger. Trim wise I put it on most bits but if it can be touched by a 100mm sphere (large orange) it needs to have a radius on it. |
Ken
I used cable glands on the rod ends the same as Dave. The lockouts I used cut down motocross bike fork gaters cable tied on
Yep nut covers and cable glands.
