Wired up my headlights at the weekend and they all work fine apart from the flash.
Am I right in thinking this is a problem with the switch? |
Are you using the later style Sierra switched earth column switches?
If so have you got pin 15 of the indicator / dip-main beam switch connected to earth? This is the pin that the main beam relay earths through when flashing the lights.
They're from a 92 so I guess they are the later ones
Will have to check that out Thanks |
Checked it out and that was the problem!
Thanks it saved me a whole load of grief and head scratching 😀 |
No worries, glad you got it sorted
