Old 22nd June 2015, 08:34 AM
Rosco Rosco is offline
Default Haynes Shaft Length
Im trying to sort some drive shafts for my haynes roadster, ive made the wishbones to the correct length to take standard wishbones
i have a distance when level between the flanges of 490mm and 450mm (100mm bolt on shafts)
the shaft lengths is can find are
520mm
466mm
480mm
508mm
anyone have any ideas?
My Build Thread
Old 22nd June 2015, 01:58 PM
Sierra or MX5 ?
Old 22nd June 2015, 02:58 PM
Sierra, sorry
My Build Thread
Old 22nd June 2015, 04:35 PM
7 in diff or 7 1/2,they are two different lengths
Will check tonight or someone will be able to tell you length.
Just make sure you have the up to date as the whishbone lengths quoted were wrong by 10 mm iirc.
Old 22nd June 2015, 08:45 PM
7 inch, yeah the wishbones are correct as I've already remade them, if you can let me no that's great
My Build Thread
Old 23rd June 2015, 10:03 AM
Depends what type of ends are fitted ,lobro or large nut on the end.
795 for the lft and 835 for the rht would be right for the ones with a nut on the end ie original sierra.
Lobro have two six bolt flange's on either end .
