Old 31st August 2015, 06:21 PM
Rosco Rosco is offline
Default WANTED Sierra handbrake cable fitting
I'm after one of these end fittings so I can either solder or bolt on to a fresh cable
My Build Thread
Old 31st August 2015, 09:36 PM
Hi,
In case you don't find these ends, here is what I used (bicycle cable stop):
2014-07-24_15-20-26 by Sylvain ROIG, sur Flickr
It works a treat because it seats nicely into the "hook" of the lever. It hasn't moved since the car has been on the road. The other good thing is that you can pre-adjust it.
Good luck
Old 1st September 2015, 09:47 AM
You are probably better trying to mod the other end as I doubt you will find anything to replace that cable end unless you make it yourself.
Ford galaxy/sharan may fit.
Old 1st September 2015, 11:32 AM
Ianr Ianr is offline
If you go to a marine maker of rigging I think you will find they can sort out something that looks like that - and crimp it on
Old 1st September 2015, 09:44 PM
It turns out that mk sportscars sell them so will post a pic when it turns up, cheers for the help tho guys
My Build Thread
Old 3rd September 2015, 08:51 PM
Turned up today from mk, perfect, will stick a pic up when I get a min
My Build Thread
Old 3rd September 2015, 09:14 PM
My Build Thread
Old 4th September 2015, 10:18 AM
RAC/AA etc use them to repair cables.
Old 4th September 2015, 09:58 PM
Badger Badger is offline
I thought there was some issue with using bolted on connectors on the handbrake getting through the IVA?
Old 8th September 2015, 08:50 PM
No I don't think so, I think it's if you bodge two cables together on the handbrake so it can't even out the force
My Build Thread
