![]() What camber angle set up have people used front and rear? Looking at either optimum tyre life versus optimum handling.
![]() 0 on the rear,2/3 deg negative on the front and some toe in.
You may have to put more on for self center at IVA.
![]() -0.5 rear, -2 front. Tyre life is a non-issue. I got 2 seasons, about 6000 km out of a set of R888's. Anything harder will turn to wood before you wear it out, unless you do donuts, burnouts or drift all the time.
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. Last edited by alga : 13th March 2016 at 12:01 AM. |
![]() Thanks, looks like you are both roughly in agreement, I will go for 0 on the back and 2 on the front as a start point. I have gone for a slight toe out at the moment for quick turn in, self centring seems to be fine.
![]() toe in at front makes car more stable at speed
http://s36photobucket.com/userswannt...130809.2000249 |
![]() i run 1.5 front 0.5 rear and 0,25' toe-in last time i checked but i would say ride height is more of an important factor along with correct spring rate and suitable damping and tyre pressure.
first time out i ran everything at zero camber and toe and slightly soft felt fine on the road and tuned in from there. |
