Old 14th September 2016, 07:25 PM
SteveH SteveH is offline
Default Td04 turbo
Evening everyone
I trial fitted my td04 turbo today after getting my manifolds from blackcat
And have found that the actuator is sitting to high
So high that the bonnet won't fit now
Any ideas as to what I can do with the actuator so I can get my bonnet to fit
My son said cut a hole in the bonnet and have it showing
Old 14th September 2016, 10:09 PM
NeilW NeilW is offline
Can you not somehow get the turbo to mount toward the bottom of manifold using some kind of angled exhaust pieces and flanges? Or just chop bonnet and glass a vent of some type over it?
Total Spent so far - £xxxxx
Last Purchase - Engine mounts, steering wheel, slave cylinder.
Old 14th September 2016, 11:07 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
The actuator does look quite large is there a smaller unit available the will give you the clearance
Old 15th September 2016, 08:15 AM
I've been looking at how I'm going to fit mine in over the winter. It is tight so I decided to make a custom manifold putting the turbo a little further back in the engine bay and a little lower but also have managed to design a manifold with a better flow. well it looks better to me.
https://www.flickr.com/photos/124541...posted-public/
Old 15th September 2016, 08:12 PM
Was having a think about this today while I sat there staring at it and thought
What about if I turned the actuator over
And on a quick trial fit it may look like it will be low enough to clear the bonnet
After work tomorrow I'm going to get straight on it so I'll post a pic when I'm done
Old 16th September 2016, 04:28 PM
So I turned the actuator over and I'm happy with where it will sit
Just need to make a bracket
