Old 19th July 2009, 12:06 PM
old_bill old_bill is offline
Unhappy front sb's
I started to fit the front suspension brackets and found that I have a gap between the chassis and the bracket. I have checked the frame dimensions and they seem OK. I had a word with Spikehaus as he had the same problem. There is apparently a thread on this but I can't find it.
Should I place a spacer between the chassis and bracket or should I manufacture new brackets with the dimension to the bracket hole altered to suit?
Thoughts and ideas appreciated
Bill
http://www.flickr.com/photos/old_bill/
Old 19th July 2009, 12:09 PM
just put a spacer behind the bracket, i too had the same problem.
Old 19th July 2009, 12:13 PM
My vote would be for a spacer too. I'm sure you will do something suitable strong, and I think that would be better and more rigid than a bracket with longer arms.
Old 19th July 2009, 12:47 PM
As with many others, I too had a gap that required a spacer ( 3mm to be exact )
Checked & double checked the bracket alignment jigs, spot on
As long as the brackets are in alignment with the book spec, all should be fine
Old 19th July 2009, 12:59 PM
fabbyglass
Don't shout at me but why not make the front chassis section that much wider to account for the gap.....
Old 19th July 2009, 01:02 PM
Probably because using spacers would be a lot easier/quicker than going back and redoing the front frame
Old 20th July 2009, 12:27 PM
mark mark is offline
It seems as though the person who doesnt need packing behind these brackets is the odd one out on this one!
I did the same as have many others have just pack them out and weld em up!
Old 16th August 2009, 07:54 AM
Matthew Matthew is offline
Bill
Just reached the same point you did and have exactly the same problem - about a 3mm gap between FF2/3 and the suspension bracket. I've checked and re-checked the dimensions but for the life of me can't see where I've gone wrong.
I'm going to do the same as everyone else and pack the brackets out, but if I was to build another roadster I think I'd add four blocks to the jig for the front frame so that the tubes end up in the right place. As far as I can see the suspension mount points are the part of the structure that has to be correct, and their position is just a function of how well you align everything else. Any errors get magnified because of the angles involved.
Matt
