Old 8th August 2009, 10:36 AM
shlee1100 shlee1100 is offline
Default Cortina upright wishbones
What changes need to be made to use Mk3 cortina uprights? Sierra uprights are not easily available here in Australia & I have the Cortina parts at hand.
Thank you,
Ash.
Old 8th August 2009, 10:48 AM
redbertonex19 redbertonex19 is offline
Hi
I have used Cortina uprights, I know I left the bottom wishbone the same and modified top, will measure top and let you know. Leaving the bottom wishbone as standard maked the front track approx 20mm wider, but I left it this way so if I have to use Sierra uprights I only have to remake upper wishbones. Car seems to drive fine with Cortina uprights and locks front brakes first, have just fitted some grooved discs so will have to check brakes again. Will measure upper wishbones today and post measurements later.
Jeff
Old 8th August 2009, 11:00 AM
Hi
Just measure and overall length books says 236mm mine 258mm, Bush centre to threaded section centre book says 120mm I made it 124mm, I left the threaed section straight no 8 degree angle. All other dimensions the same but the angles of the seamless tube will change.
Hope this helps.
ps
Also found that steering rack extensions need to be approx 20mm shorter.
Jeff
Old 14th August 2009, 08:28 AM
Smile
Thank you Jeff, your info will be of great help!
Cheers,
Ash.
Old 9th September 2009, 07:29 AM
Adam R. Adam R. is offline
If you curently use Sierra hubs then you'll need to shorten the bottom wishbone by 35mm in order to use these and retain the same suspension geometry.
info from:
http://www.ekmpowershop9.com/ekmps/s...etry-350-p.asp
carbon master
hayens roadster + carbon westfield body
English is not my native language.
If my grammar/spelling is off please correct me, I'm still learning!
Old 16th September 2009, 09:59 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
This may help you work it out
