Old 11th August 2009, 03:49 PM
axle's Avatar
axle axle is offline
Question Sierra M/C oreintation
Hi
Could some body tell me as if this the correct way to run the brake pipe from the Sierra's master cylinder to the front and the rear pipes.
There are 3 ports from the M/C , the one at the back to the back wheels and the 2 at the front one to O/S and the other to the N/S?
Regards Axle
Old 11th August 2009, 03:51 PM
Dead right with your last paragraph.Back to rear front to left and right.
Old 11th August 2009, 03:56 PM
as Flyerncle has said, just a little further info......
the forward union is off side front
center union is near side front
rear union is to the rear T piece
as when flyerncle & i stripped my car, i bent the bits of cut brake pipe that was still attached to the M/C in the direction they were originally feeding to.
Old 11th August 2009, 04:00 PM
"as when flyerncle & i stripped my car" ? You went home !
Old 11th August 2009, 04:04 PM
axle's Avatar
Thumbs up
cheers lads much appreciated!
Regards Axle
Old 11th August 2009, 04:06 PM
oh yeah i did didn,t I ???
but YOU sent me home, by the time i got back with my van you had practically finished stripping the car,
remember the look on my face??
but i do remember bending the bits of brake pipe on the M/C
Old 11th August 2009, 04:08 PM
jimbo jimbo is offline
Sorry to be thick, but when you say forward union do you mean the one closest to the pedal or closest to the front of the car?
Old 11th August 2009, 04:10 PM
No probs Jimbo,rear single hole to back, double holes to left and right front.
Old 11th August 2009, 04:11 PM
the forward union is the one closest to the front of the car, sorry i should,ve made that clear in my reply earlier.
