Old 26th August 2009, 11:13 PM
Tatey's Avatar
Tatey Tatey is offline
Default Marking up steel
I've been searching google and i cant seem to find the answer. What type of pen/or similar do steel suppliers use for writing on the steel. I have tried using sharpie markers but the pen fades after a while.
The stuff the steel suppliers use seems to last for ever, i've mainly seen it in blue and its kind of like a paint on the metal.
Any help will be much appreciated.
Old 26th August 2009, 11:20 PM
i think its called "steel blue" marker, some hardware shops sell them.
what you marking up? or is it for marking the cut etc?
Old 26th August 2009, 11:25 PM
Tatey's Avatar
Mainly used to mark up what part the bit im cutting is and to make it easier to see where to cut.
Cheers for your reply Andy. You helped me find what i needed.
Old 26th August 2009, 11:35 PM
as my build is so locost i used fine tipped felt pens from asda & a steel scriber, & if needed i scribed the line onto plate steel & used the edge of masking tape to make it easier to see.
but then again i,m a tight git
Old 27th August 2009, 12:19 AM
spalders spalders is offline
I use a permanent black marker pen - it makes a line about 5mm wide so I can black out an area really quickly then scribe through this leaving a bright easy to see line to work to. Don't get too high on the pens though
Spalders
Old 27th August 2009, 11:26 PM
I 'acquired' a nice thin permanent marker from work for writing on bits, then use a scriber to show the exact cut line.
Borrowing stuff from work is very locost
Sean
