Old 15th September 2009, 07:44 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Default Electronic speedo
Hi all,
again getting to far ahead (in my head - planning).
I want to use an electronic speedo, what are the options??
Do I take a drive from the mechanical output on the gearbox (T9)? If not do I need to blank it?
What are others using?
Daz...
Old 15th September 2009, 08:36 PM
Jimmyd Jimmyd is offline
Usually the simple method of an electronic speedo is a sensor mounted to a front hub to count the rotations and then you programme the speedo with the circumference of the tyre.
I don't think you need to blank the output on the t9.
J
Old 15th September 2009, 10:21 PM
TSM Locost's Avatar
If you mount the sensor on the front hub @ the IVA they wont be able to check the speedo as they only work off the driven wheels unless you have FWD.
Be Lucky, Mike.
Old 16th September 2009, 01:55 PM
DaddyA's Avatar
Cheers Lads,
it will be a rear mounted sensor then!!
Daz...
