Old 8th October 2009, 12:46 PM
dogwood's Avatar
dogwood dogwood is offline
Default Fibre glassing question..Fabby ??
Hi.
Im about to modify my Triton scuttle. (Widen it)
I have made up the "Splash" molding as Mark sudgested.
Question is,
Do I need to use Gelcoat before the matting or will just the resin be OK?
I intend to spray it anyway so finish is not an issue.
I have some very old gelcoat in my garage.(25 years )
Does it go off?
Sorry if these are dumb questions, but what I know about fibreglassing could be put on a postage stamp, and still have room for the queens head....
I
Old 8th October 2009, 06:10 PM
fabbyglass
Yes mate it goes off, resin and gel coat have a shelf life of a year i think it is if stored in right conditions.
You might be ok just using matt and resin as no doubt it will need a skim of filler to get the levels right as not dead flat on the top...
Old 8th October 2009, 06:27 PM
dogwood's Avatar
Cheers mate
So you think after 25 years it might be past it's best then..
I'll give it a go over the weekend, see how I get on..
Fingers crossed for me, hu ?
Old 8th October 2009, 07:07 PM
fabbyglass
Cut the matt to fit into gap, nice sharp edge for first layer then 2 over the top overlaping by 4 " or so either side...dont get it too wet and not too dry
Old 8th October 2009, 07:22 PM
dogwood's Avatar
So sort of in be tweeny......
Cheers for the advice, greatly appreciated.
Coz I know nuffffin about fibreglassin.
Old 8th October 2009, 07:43 PM
fabbyglass
Yeah something like that but you will know when you do it, have a look on the underside(if i did it right that is... ) how it looks and aim for that finish..although it's cured it kinda looks wet/shiney well ish..Too much resin and it will get hot and be brittle not enough and it will fall apart.
