Old 16th October 2009, 12:38 PM
Vedde Vedde is offline
Default Cad for the 7 for the grille?
Hi there
does anyone have the 7 emblem in a cad file? I'm in sweden and would like to get i water cut from alli at my local guy. I haven't been able to find any cad drawing of it.
Here is a picture of what I'm after:
The measurements are 20 cm wide and 18 cm high as stated in the picture.
If you have it and willing to share please e-mail me at fredrik@engzell.com
Thanks
/Fred
McSorley+Rorty+Gibbs Locost Builder
Sweden
Old 17th October 2009, 01:52 AM
I just traced your photo with lines and arcs in QCad, here's what I got: http://locost.lt/stuff/7.dxf
Old 19th October 2009, 08:28 AM
Thanks, need to get someone with a cad programme to have a look at it. Is the size set to 18 x 20 cm? otherwise it'll be a small thing to put on the grille.
Having a hard time saving the file to my computer, am I doing something wrong?
/Fredrik
Sweden
Old 19th October 2009, 09:43 AM
/Fredrik
Size shouldn't matter with CAD. If the water cutter has requested a CAD file, then that means he has CAD and can set the appropriate output size. If they have requested a cad file, then a DXF is almost perfect to hand over.
DXF is drawing interchange format, and almost all CAD programs can read it. It's how we transfer information between incompatible CAD platforms
I have just opened the DXF in AutoCAD 2008 (my day job) and it is 191mm high, and ~200mm wide (200.0046 or something)
One thing though, the emblem is not symmetrical in CAD. Everything seems a little 'skewed'. It's not a lot, and probably wouldn't be that noticeable, but with CAD accuracy is a given
Sean
