Old 25th November 2009, 06:43 PM
dogwood's Avatar
dogwood dogwood is offline
Default Bleeding brakes.
I hate bleeding brakes......
Or should that read I hate bleeding, bleeding brakes
I'll wait for AshG to elaborate........
Old 25th November 2009, 07:22 PM
gingea1pom's Avatar
was it those dodgy bleed nipples or some other issue.
Im intrigued now.
Build Pictures
Old 25th November 2009, 07:47 PM
dogwood's Avatar
Just spoken to Ash on the phone.
It wasn't the dodgy bleeding nipples.
It looks like a dodgy bleedin caliper
Spent ages this afternoon trying to bleed the system
But still had a soft pedal.
Ended up blocking off each pipe at a time till we got a hard pedal.
Front right was the culprit. Still not sure what was causing it though.
Old 25th November 2009, 10:49 PM
Thing to try if you have pedal problems,if you have rubber brake hoses clamp them gently and see if the problem goes away,if not put your foot on the brake with it clamped and get someone to release the clamp and see if the pedal moves,good indication of air in the system.
Old 25th November 2009, 10:53 PM
front drivers side caliper isnt playing ball. have removed it and capped off the flexy hose and the other 3 brakes are rock solid. am going to strip down the caliper tomorrow and see what the problem is.
if it cant be fixed then im after a replacement front drivers side caliper.
Old 25th November 2009, 11:19 PM
Ash
GSF car parts at Thurrock are doing exchange recon callipers for £24 each +vat.
Might get you out of a fix.
Adrian
