Old 18th December 2009, 06:37 PM
aerosam's Avatar
aerosam aerosam is offline
Default Are these shears any good?
Guys, I'm thinking about starting to fabricate the ally paneling for my car and was wondering if the thses air powered shears are any good. Has anybody used them? Is there a better version out there?
http://www.machinemart.co.uk/shop/pr...s-screwdrivers
Thanks and Merry Christmas to everyone!
Old 18th December 2009, 06:53 PM
waste of time those. they just bend the ali. i did all of mine with 1mm makita ali cutting discs on the angle grinder. they are £15 a pack of 10 at screwfix which seems expensive but is actually pretty cheep as they last for ages. i only used two discs to cut every ali pannel on the car. they go through it like butter and can give a super super straight cut. you can also get round mild corners with them if you are gentle and take your time
i would assume you already have an angle grinder so £15 is pretty cheep compared to £52 for the airsheers that just wrinkle the edge of the ali
Old 18th December 2009, 07:06 PM
[quote=AshG;27309] i did all of mine with 1mm makita ali cutting discs on the angle grinder.
A word of warning here wear a dust mask when grinding or cutting ali as it is very hazardous to your long term health.
Old 18th December 2009, 11:51 PM
aerosam's Avatar
Well that sorts that one out then - thanks guys!
Old 19th December 2009, 08:53 AM
TSM Locost's Avatar
Check out Fast tools on the bay. 20 x 115mm ( INOX ) stainless discs for £10.25 post free. Item number: 360182020111. I always use inox as they last longer and cut cleaner on ali.
Merry Christmas and good luck to all car builders
Be Lucky, Mike.
Old 19th December 2009, 05:48 PM
Nice find was that, thanks.
Been paying nearly a quid each for those
I was down to my last one & now have some more on the way
