Old 15th January 2010, 04:31 PM
AndyLockwood AndyLockwood is offline
Default Co2 cylinder
Does anyone in the devon area have a Co2 cylinder i can borrow/buy/loan to save on disposable bottles or overpriced BOC charges.
Andy
Old 15th January 2010, 05:10 PM
Tatey's Avatar
Tatey Tatey is offline
If you have no luck here try http://www.mig-welding.co.uk/forum/index.php, as thats where i managed to get mine for free . If that fails, talk to your local pubs and see if you can blag one from them.
Old 15th January 2010, 05:21 PM
ok ill check it out thanx.. local pubs just changed hands so dont think ill have much joy there
Old 15th January 2010, 05:30 PM
davidimurray's Avatar
If that fails try giving Andy Kearsey a ring at Target Tools and Equipment. Andy is based in Gloucester but has a few distributors around the UK.He does a deal where you hire a bottle that costs around £50 for 3 years, there is a refundable deposit of around £30 and then around £25 per refill. His number is 01452 739005 or email targetgas@blueyonder.co.uk. Can supply Argon/Co2 or straight argon as I get for Tig welding.
Old 15th January 2010, 05:40 PM
That's commonly known as theaft, the bottles usualy still belong to the brewery or the gas supplier directly. Just like Bear Barrels that you can get done fore if found with them.
I use Clarke extra Fill, they last much longer and only cost a quid more than normal bottles.
Old 15th January 2010, 05:44 PM
Tatey's Avatar
You learn something knew everyday .
Old 15th January 2010, 06:00 PM
I know this relates to the kegs, but brewerys are not thick when cylinders of C02 go missing..
http://www.kegwatch.co.uk/press.htm
Old 15th January 2010, 06:51 PM
got mine from energas. £35 for a 6foot tall argon c02 mix gas no rental charge just take it back when your done with it.
think it was £50 for pure argon. they have depots dotted around from the Birmingham upwards. the bottles are so big that they will last a couple of car builds so its worth the drive.
Old 16th January 2010, 08:44 PM
ACE HIGH ACE HIGH is offline
Try your local fire extinguisher people.Over her they sold me a retested Co2 cylinder with the correct fittings about $35 another $15 to fill it ,then only about 15 dollars a fill for 10 years for another retest,probably a bit dearer these days,often these bottles can be purchased out of date for free or $5/10.
If you use MIG I believe that CO2 is the best way to go,a bit more welding spatter ,slightly stronger and a lot cheaper than BOC or anyone else.
And consider Oxy/propane(LPG)and straight propane for heating,instead of Oxy/Acetelene.David
Old 16th January 2010, 10:15 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
hi, i have several pub style bottles the best one is ali about 6" dia 3ft tall i get it filled at a local fire extinguisher engineering company they pump it in for £1 a kilo so costs £6.50 a fill
you could prob get one from your local and do a swap return thing if you have a friendly landlord
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
