Old 3rd February 2010, 04:38 PM
Enoch Enoch is offline
Default Engine Height
Hi Folks, can anybody tell me how far below the chassis rails the bottom of a pinto sump is on a standard build? I am fitting a 2.0 dohc and MT 75 and intend to use the position of the centre of the diff to determine the height of the engine / box. I am not sure at this point if I need to worry about modding the sump / bellhousing. I have a gut feel that it will give me about 4 - 4 1/2 inches ground clearance at the sump - anyone advise?
Thanks in advance,
Enoch.
Old 3rd February 2010, 05:00 PM
les g les g is offline
PM Axle
he,s your man regarding fitting a Twinky his is in
and he will share the pain with you
cheers les g
Old 3rd February 2010, 05:40 PM
I used a DOHC sump on my RS2000 16v engine (same block). I had to cut around 30mm off the bottom of the sump, add and extension and baffle it, to make it suitable for fitting into the chassis. But I'm using a type 9 gearbox, because its much slimmer and better suited to the car.
Old 3rd February 2010, 09:19 PM
Thanks guys, I am just trying to judge it against the pinto that the car was designed for. I am thinking that it makes sense to modify the efi inlet manifold to the engine can sit 1 inch higher rather than chopping the bottom off the sump. I have communicated with Axle but am just considering a different approach.
Old 3rd February 2010, 09:43 PM
mr-p mr-p is offline
I will be getting to this point soon, I,m sure someone posted pics of the DOHC installed, i will be going carbs route so the EFI can be junked. I lifted the motor in a couple of weeks back & first looks thought that the sump would be way low.
Is it just the case of lifting the engine & having a bit of angle on the shaft.
Looking at the sump it is no lower than the bottom of the bellhousing so cant see how mods would work??
Old 3rd February 2010, 09:52 PM
That's the issue really, the sump bottom is level with the bell housing so modding the sump alone won't do anything. Having had a think about it what I think I need to know is - what is the distance between a bottom rail and the road when the car is at it's correct ride height? From that I think I can work everything else out.
Enoch.
