Old 9th March 2010, 10:59 PM
dan_g8 dan_g8 is offline
Default seat belt nut grade
hi, i bought some nuts off of ebay for my seat fastenings. i was told by the seller that they were grade 8 (im guessing they need to be 8 or higher) however after fully welding them onto the chassis plate and fully welding the plate onto the chassis i realised that i couldnt see a 8 stamped onto the nut. is there another way of identifying the grade of the nut? i have got a feeling that they are only grade 1!
attached (hopefully) is what is stamped onto the nut.
Dan
Old 9th March 2010, 11:11 PM
Doesnt look like it to me.It would be stamped 8.8 or have a line from each corner of the nut making 6 lines on it or could have BD on it.
Old 10th March 2010, 08:32 AM
The IVA doesn't check the grade of the nut, if thats any consolation
Old 10th March 2010, 01:35 PM
would grade 1 nuts be ok to use then ? some one at work just told me that it doesnt matter too much about the tensile strength of a nut because the "bolt should have all of the strength"
Old 10th March 2010, 01:46 PM
Well thats kind of true as its in shear when under load. I used unmarked nuts for the lower mounts (supplied by Europa) and the rears are just tapped mild steel rod.... so nothing fancy.
Old 10th March 2010, 06:30 PM
thats good enough for me, think ill keep them as they are. Thanks for your responses.
