Old 16th March 2010, 05:21 AM
filip arvidsson filip arvidsson is offline
Default Spacer tube
Hi!
I am mounting the front suspension brackets with use of the jig from the book.
In the pictures of the jig it shows a spacer tube before and between the brackets, I can't find the dimensions of the spacers.
Does anyone know what they are or where in the book they are described?
Thank you
Old 16th March 2010, 12:10 PM
robo49 robo49 is offline
Default front jig
Hi Fitted mine last night all I think the spacer is for is to stop the jig hitting the front cross member when you line the bracket up with the messurements in the book all I used was 4 flat washer,s on each side apeares to be ok
hope that help,s
rob
