			 iv got some adjustable rear lower wishbones for the toeing in and out, obviously got rose joints on the end. whats the best way to mount them for iva and has any1 got any pictures of some setup?
			 they the ones from ebay the other day?
	You only get a woosh with a dump valve Build Thread Man Cave Mantiques Cecil Street Auto Repairs Garage Carlisle Build Cost £4181.65 - Last - Wheel Cylinders  |
			 nah mate my chassis is the old 3ge chassis wiv inboard suspension, which come with the wishbones.
			 this is what iv done so far. but not sure if its acceptable as the rose joint whole is bigger than the allthread so might move about in time, ok at the minute.
			 Try McGill motorsport for the right spacers
			 the spacers are fine to be honnest. what the problem is that the allthread that goes through the up right is the right size diameter but the rose joint hole is larger so theres play between the allthread and rose joint hole. if that makes sences?
			 just looked on that site are you on about misalignment spacers/reducers?
			 Personally i would buy some rose joints with the right size hole in. 1/2" will be too big as its 12.7mm and the bolt holes in the brackets are 12mm.
