Old 27th March 2010, 11:21 PM
geeman's Avatar
geeman geeman is offline
Default Doing bodywork
Ok, well im mock fitting the bodywork now, ive got full Fiberglas set from titron. I was wondering for the side panels, for cutting holes for the front wishbone/steering setup, should i have seen people have cut seperate holes for each thing coming through the chassis, but is there anything bad about just cutting a large section of the side panel off, so i dont have to spend extra time cutting and finishing loads of holes?
my build pics
Old 27th March 2010, 11:26 PM
-Engage frank mode- Well there is no readon not to do it appart from it lookinng crap.. - Disengage frank mode -
-Engage helpfull mode - Put the effort in, it's not worth shortcuttign it, you will end up looking at it and thinking it looks bad, and there's only one person you can point the finger at.. - disengage helpful mode -
Old 27th March 2010, 11:29 PM
geeman's Avatar
thought as much, its just i did the right side panel today, and did each hole separately, only to find i have to make one hole slightly larger as i had cut it slightly off, which p'ed me off a bit, so i thought i could just cut a giant, hole, guess ill do it properly then
my build pics
Old 28th March 2010, 09:12 AM
Just make a good template.
Old 29th March 2010, 12:06 PM
I might be wrong, but I think Roadster No. 1 has huge holes judging by the photos in the book.
Old 7th April 2010, 12:01 PM
geeman's Avatar
ok, im mock fitting the firbreglass rear tub and arches now, should i just cut a big hole out of the rear tub for the wishbones, and how should i mount the rear arches?
my build pics
