|  chassie tests do ou know wat test will be done on the chassis at the test and can i have them or do them befor hand to make shoure it passes ?? thanks Last edited by bobbyh : 7th January 2008 at 12:38 PM. |
|   The SVA test? If so, the only test is a visual one. If your welding looks ok in the places that the tester can see then you should be fine. They don't do any dismantling or torsion testing. Hope this helps Chris  |
|   oh cool thnaks |
