Old 22nd April 2010, 09:47 AM
jasongray5's Avatar
Default Fuel tank sender position problem
My tank arrirved today
Looking good and all that, however, slight mis-communication with the guy who made it and the sender hole is in the side, about 3/4 of the way up, instead of in the top, The sender I have came with a rubbery thingy, do we think it will be fuel tight, or shall I move it to the top, and weld a plate over where the existing hole is?
Cheers Guys Jas
Old 22nd April 2010, 10:33 AM
Have you a picture of the tank & sender unit Jas
It will be a lot easier to give you some sound advice if you do
I guess if the sender and rubber ring are made to be used together & it was designed to be side mounted in an alloy tank, I can see no reason as to why it might leak .
The sender probably has a bendy arm that you can re-profile to give you the full range of movement & accurate reading
Old 22nd April 2010, 11:23 AM
jasongray5's Avatar
There ya go! Was planning on using self tappers to hold it in!
Old 22nd April 2010, 11:29 AM
Should be okay, you can bend the sender arm for full travel. Be better than blanking the hole and cutting another in the top.
If in doubt you can get a tube of specific sealant for sealing the gaskets:
http://www.workshopsupplies.co.uk/co...e_sealant.html
I use Dirko Grau which is great stuff.
AndyH
Old 22nd April 2010, 11:46 AM
jasongray5's Avatar
Cheers guys!
Andy, do you mean the stuff at the top of the page, (the red stuff)
Cheers Jas!
Old 22nd April 2010, 12:40 PM
Sorry Jason,
Here is a better link:
http://scparts.co.uk/index/lang-2/lk...900e78435 53e
Cheers....>AndyH
