Old 26th May 2010, 08:13 PM
trickydicky0_16 trickydicky0_16 is offline
Default pinto expert needed
Hi got a 2.0l pinto that would not run under load,
changed wires over on coil things improved greatly. On the spot it will rev and miss a little bit try and drive it and its popping spluttering when any amount of throttle is applied and throwing fuel back up the carb. drive it steady and its almost ok?
What we have done advanced and retarded the timing and tested compression 3@ 165psi 1@ 100 psi. indicating piston ring on no 2 cylinder. Fitted and removed electric fuel pump
New
carb repair kit
rotor
leads
dizzy cap
points
condensor
plugs
in line fuel filter
no back box fitted
Three people have looked at this and yet know fix, now the head has been taken off. Bore, piston ring and valves all look ok a little cokey but all looks ok
in fact looks hardly used big question is what to do now. we are a long way in with pinto, shortend sump,stainless exhaust manifold made, side panel hole cut for exhaust,
Cheers tricky
Old 26th May 2010, 08:36 PM
Have you done a cylinder balance test by removing each plug lead and revving the engine.
Old 26th May 2010, 08:37 PM
snapper snapper is offline
Check static cam timing
check rocker gaps
set No.1 to TDC check rotor arm is adjacent to No.1 plug lead
check spark at plug
run engine with strobe and check idle advance, set to manufacturer recomendation
check spark advance at 3500 rpm with vacuum removed, should be 36 to 38 degs
attach vacuum and test again, should have more advance with vacuum and no load
problems now mean either the vacuum advance plate or the weights are giving problems in the distributor which you will see by strange advance using the strobe.
If none of this points to the problem then borrow a carb and try that.
Old 26th May 2010, 08:38 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, firstly compressions are a little low were they taken at wot?
did you check valve clearances and cam timing?
and thirdly the coil, if your using points and condensor you need the correct old style coil not one for electronic ign systems as the resistance is too low and will give almost exactly the symptoms your describing are you running a ballast resistor with your set up or a straight 12volt 3ohm coil?
hope this helps
also while the heads off worth grinding the valves in at the very least, especially if the engines done many miles on unleaded!
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 26th May 2010, 08:45 PM
cheer chaps will try these things
Old 26th May 2010, 09:03 PM
A poorly seating valve might explain the very low compression on the one cylinder, if that hapens to be one of the inlet ones it would certainly explain the fuel spiting back through the carb.
That is the exact same syptoms that I was having with my pinto engined Transit .... Never did get that running spot on & as it was sold today, I no longer have to keep chasing the problem
I hope you get it sorted OK
Ray
Do you know what .... I never even give the coil on the Transit a thought .... I ought to know better than that !!
Old 26th May 2010, 10:17 PM
Have you checked that you dont have a worn cam lobe on the low cylinder. pintos have a habbit of eating cams.
following that check the cam position at tdc cyl1 it could be a tooth out
check you have the correct timing belt there are two different belts with different numbers of teeth.
check the valve clearances.
My Pictures
Old 27th May 2010, 09:00 PM
inlet valve on number 2 edge slightly damaged flat spot on one side, would this be enough to cause this trouble. Next thing best source for new ones can only seem to find burton's do i replace them all while the head is off. Also thinking of putting a fast road cam any thoughts. It was looking like they were all ok this one was the last one out
Tricky
Old 29th May 2010, 12:03 PM
Big Vern Big Vern is offline
Hi Tricky,
You've probably done all this but FWIW.
Check plugs leads are on in the right order and firing at the right time.
Check cam timing, if the heads been off before it may be out - worth a check.
One cylinder low on comp. won't make it a smooth runner but it shouldn't be spitting back through the carb unless you have a very burnt valve - you would have noticed when you inspected it when the head was off! Check valve clearances - you could have a valve being kept open - especially as no.5 valve is tricky to adjust with the carb on.
Carb rebuild kit suggests you've stripped the carb. Now it won't take load without spitting and coughing through the carb. Hmmmm? What did you do to the carb? did you get the mixture screws, jets etc all back in EXACTLY the right places?
For me your problem sounds like fuel mixture or cam timing as you say it doesn't seem too bad if you try to pull away gently.
Try to get to the bottom of these problems first before stripping the head off again or you could just spend money and it still don't run when you get it back together.
HTH BV.
