Hi all
I am currently tearing what is left of my hair out. I've got into 3d now and am at the point that I have cut tr1/2 @1472 with 10 degree paralell ends. I offered it up and it is totally wrong. I have triple checked all of my measurements and angles and they are fine but the top rail is about 20mm to short. Any ideas what is going wrong? All of the uprights U3, 4, 5 & 6 are all situated correctly and at 90 degrees to the bottom rails - which are flat on the table.....GRRRRRRR |
Wait one HandyAndy will be a long before you know it.
Sent from my iPad, from who knows where in the world I was building but I am not now! Build Pictures Build Thread |
A photo will be a great help cheers andy |
1472mm with the 10degree cut is correct as you say,
so have you taken into account that TR1 & TR2 meet the REAR face of the front frame? If you do, then may I ask if your front frame has the 75mm "lean back angle" created when making the front frame? If so, then don,t forget that TR1 & TR2 sit on the forward leading edge of the uprights U3 & U4, I think its U3 & U4 (sorry, not got my book with me at home). hope this helps cheers andy |
Unfortunately all those points are already considered. The front frame is spot on as are all of the base measurements. I have TR1 18mm short. Hang on - I'll get some photos.
OMG that reply is without the book!
Andy, go to your local collage and see if you can do an NVQ in the Haynes Roadster Chassis, because you would not have to revise! Pictures would be good, us meer mortals might have a chance Cheers Ginge
The TR1 & TR2 rails are the easiest to remember as they are the longest single length tubes within the chassis Maybe I do need to get out more cheers andy |
OK:
TR1 resting in place - ![]() The discrepancy - ![]() The frame 75mm measured with a plumb: ![]() Measurement from BR12 to BR11: ![]() More to follow... |
Measurement from BR12 to BR10:
![]() Measurement from BR12 to FF1: ![]() Finally 90 degrees on U5 and U6: ![]() ![]() |
Aha! Well spotted - That sorted it - on closer examination FF1 wasn't sitting flat on the table - a bit of a wrnch to make the measurements as you describe and hey presto TR1 FITS!!!!!!!!
