Old 13th June 2010, 09:03 PM
will_08 will_08 is offline
Default About to lose shell?!?
Right finally stripped my donor sierra, cut the shell into 5 manageable chunks.
ground the ID in the floor pan, got the Vin plate etc
Is there anything else that could be on the shell that is often overlooked. specifically i thought i saw in the book something about removing gearbox mounts from the shell?
Any suggestions are much appreciated
Cheers Will
Old 13th June 2010, 09:18 PM
gingea1pom's Avatar
will,
I took every break pipe and connection, also every nut and bolt just to help with mocking up.
Cheers Ginge
Build Pictures
Old 14th June 2010, 12:36 PM
Thanks ginge, if it undos then ive undone it! its a sierra graveyard in my garage at the minute.
Just wasnt sure about any welded brackets that might want removing.
