Old 30th July 2010, 06:40 PM
Default BMW E30 + E36 engines
Are there any BMW fans on here and do any of you know how an E30 or E36 2ltr or 2.5 compares weight wise to say a 2ltr zetec or 2.8-9 v6?
I'm weighing up options on a new project but if it means trading handling for power I'll stay with ford units.
Old 30th July 2010, 08:17 PM
the 2.5L M20 Makes 172ish BHP compared to 150ish BHP from the 2.9
Not sure on weight but I guess the M20 is a bit heavier than the Cologne.
Old 30th July 2010, 09:38 PM
yeah I got as much from wikkinearlyright,just need to do some more research before I spend time,money and development on a project that might not go round corners as intended. There are possible plans to use a standard haynes chassis and a wider version to rebody it as a 'bruiser'.
Old 30th July 2010, 09:43 PM
Although I am using it, the ford 12v 2.9 is not brilliant.
I would pursue the BMW route as donors will be more plentiful, especialy in terms of gearboxes.
the M20 makes a lovely sound.
Old 31st July 2010, 12:00 AM
les g les g is offline
go phil go and dont hold back
those bm,s are cheap and really good
cheers les g
Old 31st July 2010, 12:29 PM
Wasn't there a write up a month or 2 ago in CKC on the new GKD '7' that rated highly that uses the BMW as a donor.
Old 2nd August 2010, 06:29 PM
aerosam's Avatar
aerosam aerosam is offline
Hi guys,
the M20 2.5 (E30 3 series) weight approx 117kg, 170bhp
the M50 2.4 DOHC (E36 3 series) weight approx 136kgs, 192bhp
Don't know the weights of zetecs I'm afraid.
Old 2nd August 2010, 06:32 PM
117 kg? Is it all aluminium?
Old 3rd August 2010, 02:48 PM
aerosam's Avatar
I believe it is, yes.
Info from here:
http://www.bimmerforums.com/engine_faq.php
Old 3rd August 2010, 05:33 PM
That's got to be an undressed engine. Still very light!
