Old 31st July 2010, 10:56 PM
David_17's Avatar
David_17 David_17 is offline
Default Diff mounting plates and seat mounts.
As some of you may know, my welder is running off a generator, as my lockup doesn't have electric.
Sadly, it isn't quite powerful enough to weld 5mm plate, the engine just dies. For the diff brackets this isn't a problem, as i can take them home and do them off the mains. But the plates on the chassis (that the diff brackets bolt to) i'll struggle with.
Would i get away with using 3mm plate? Or have i got any other options that people can come up with?
Also, my seats will be bolted to 25mm box section (2mm wall), would the iva man prefer if i bolted right through the box section, or drilled a hole bigger than the bolt head on one side of the box, then bolted it through the hole (if that makes sense)
*updated 7/6/11*
Old 1st August 2010, 08:17 AM
You should be able to weld the 5mm plate if you prep the plate properly. Grind a 45' angle along the edges,take your time and fill the gap in with a Z pattern this is called stich welding. Your front wishbone plates, grind the welds out and them do them again. Holding the tourch in your right hand (if right handed reversed for left) at about 45' so you can see the wire, work from right to left so you can see where your going. You need to push the heat in to the plate not drag the weld over cold steel,this time use more power slower wire feed and move the torch slower.
Old 1st August 2010, 11:36 AM
I am in the center of the Toon if you want it welded.
PM for details.
Old 1st August 2010, 06:04 PM
David_17's Avatar
Cheers for the offer, but i can weld the brackets at home no problem. It's welding the 5mm plates to the chassis which are going to cause a problem.
I'll try talon's method of grinding a 45' angle on the plate and see if it copes.
Anyone know about mounting the seats to box section?
*updated 7/6/11*
Old 1st August 2010, 08:31 PM
Grinding weld prep bevel on the 5 mm plate should reduce the power needed to about that of a butt weld of 3.3 mm plates.
Old 2nd August 2010, 01:41 PM
Cant see it being a problem being bolted to box section , i would bolt right through the box section.I think you are supposed to use large load spreading plates under the bolt/nut but 2 points to think about are;
1 If you are mounting the seats on runners this will raise the seat height quite considerably.
2 If you decide to change the seats or runners in the future and cant use the original holes there wont be enough room to slot the holes or drill new ones.
Dunno if that helps much really
